Axelera Server 150p: Tested Host PCs
Validated host systems
The Metis 4-chip PCIe card (PCIe Gen 3.0 x16, full-height, three-quarter length, single slot) works with any host that meets the datasheet requirements. We maintain a list of validated systems tested by Axelera and our partners, covering desktop PCs, industrial PCs, and edge servers.
System-specific notes
Advantech MIC-75G30
Learn more about the Advantech MIC-75G30
| Item | Detail |
| PCIe power cable included | Yes (with GPU). An off-the-shelf 6-pin male to 6+2-pin male PCIe power cable is compatible (example). |
| Tested configuration | Intel CPU + 2 Metis 4-chip PCIe cards |
PowerSpec G450 Gaming PC
Learn more about the PowerSpec G450 Gaming PC
| Item | Detail |
| PCIe power cable included | Yes (with GPU) |
| Tested configuration | Intel CPU + 3 Metis 4-chip PCIe cards |
| Other notes | Used 1x PCIe power cable splitter and 1x extender to power all 3 cards. |
Lenovo P360
Learn more about the Lenovo P360 Tower
| Item | Detail |
| PCIe power cable included | Yes |
Installation notes:
- The physical fit in this system can be difficult. Proceed carefully; removing the backplate can make it easier (the card is large for the available space). Read these instructions and look at the accompanying pictures.
- Connect the auxiliary power cable before plugging the board into the host.
- Insert the board very carefully to prevent scratching or damaging components on the board or host.
- Route the power cable so it does not block airflow.
SuperMicro IoT SuperServer SYS-322GA-NR
Learn more about the SuperMicro IoT SuperServer SYS-322GA-NR
| Item | Detail |
| PCIe power cable included | No |
| PCIe power cable adapter | PN: CBL-PWEX-1362-45 - converts a 16-pin VHPWR cable to a 6+2-pin cable for the PCIe 4-chip card. Available through OEM only, not through Axelera AI. |
| Tested configuration | Xeon server + 5 Metis 4-chip cards |
Aetina AIP FR68
Learn more about the Aetina AIP FR68
| Item | Detail |
| PCIe power cable included | Not included |
| Tested configuration | Intel CPU + 1 Metis 4-chip PCIe card |
