Axelera Edge 130p: Integration Requirements
This article outlines the system requirements and integration guidelines for the Axelera Edge 130p. For optimal performance and compatibility, your system should meet the specifications below.
System requirements
RequirementDetails
Host interfacePCIe Gen. 3.0 x4
Mechanical form factorPCIe half-height, half-length, single slot (HH, HL, SS)
Power ratingPCI-SIG compliant power slot, 75 W recommended
Host CPU compatibilityIntel® Core™ processors, AMD Ryzen™ processors, Arm64 (aarch64) processors
Operating systemNative support tested on Ubuntu 22.04
Containerised supportDocker images available for use on other Linux distributions
Additional notes
  • PCIe power: while the Axelera Edge 130p typically runs at low power, a 75 W PCIe slot helps maintain stable operation under high workloads.
  • System cooling and airflow: the PCIe card includes active cooling, so make sure your system has sufficient airflow to avoid thermal throttling.
  • Other platforms: on non-Ubuntu Linux distributions, deploying via Docker is recommended to simplify dependency management.
